9 years agoThe Code/s Which Will Set the Internal Osc. to 4MHz for PIC16F628
Good day,
Could you please help me with the code/s which will set the internal Osc. to 4MHz for a PIC16F628. I used the following for a external Crystal for 4MHz. Device = 16F628( pic16f628 pdf (http://www.kynix.com/uploadfiles/pdf8798/pic16f628-042fp_200619.pdf) ) Xtal = 4 All_Digital = True Dim D As Word Int: TRISB = %00000000 PORTB = 0 D = 150 Main: High PORTB.0 DelayMS D Low PORTB.0 GoTo Main Now I would like to use the internal Osc. to do the same as the external Osc. Thanks very much1 Reply
Hello Whatry,
Your question is even more likely to get answered properly on the MICROCHIP forum. This forum is for INTEL/ALTERA products, MICROCHIP is another company. http://www.microchip.com/forums/ is the MICROCHIP forum. Best Regards, Johi.
