14 years agoText file to Flash to VHDL
Hello, I am trying to access the contents of a text file (full of binary data) via an array in VHDL on my Cyclone II device. I would like to output one bit per clock cycle to one of my FPGA pin...
14 years agoThanks for the reply.
I am using a custom board with a Cyclone II EP2C20Q240. An example would be great, or if that's too much trouble a set of instructions would suffice as well. I haven't been able to find the webinar you mentioned. How do I access/incorporate the Avalon-MM commands (I'm not sure what Tcl is)? This may sound like a silly question, but would this be from Quartus or the Nios IDE? I tried browsing through the available files generated by SOPC Builder but couldn't find any. Most of the resources online consisted of PDFs with high level design explanations. Perhaps I'm not utilizing the altera website to its fullest potential and the information is readily available. I am a novice so excuse my ineptitude.
