10 years agoteraterm setting for sd card boot up. in cyclone 5
I 've just received my board, started to play with the SD card boot, the problem is when i use the teraterm with the setting mentioned, nothing printed out. but when i use the putty software and also...
10 years agodid you change your option to tera term VT, in good sign? otherwise you will not see some printing from the terminal...in new lines
