16 years agoTCP/UDP Checksum Error
Hi all, I met a weird issue about tcp/udp checksum. The TSE works well under uClinux without any FCS error. It can ping remote deivces, but fails to communicate with others due to the tcp...
14 years agoHi,
I have the same issue as the guy who started this thread.. I updated my linux-2.6 branch with v2.6.35 using a git pull.. When I do menuconfig, the "ehternet (10 or 100Mbit)" sub menus for the altera TSE SLS and experimental has vanish... I ignored this and chose to build the Uclinux instead... When I flash program the image to my board and do an ifconfig, the one that only shows now is the loopback.. I wonder what happened to my other ethernet connection.. before the pull, I am able to ping to and out the board. .. Please advise.. I would really like to make this TCP working.. --- Quote Start --- Fixed. Please pull update. Thanks. - Hippo --- Quote End ---
