16 years agoTCP/IP via TSE and Marvell PHY
Hello, I have the Nios II dev board Stratix II edition. In addition, we have the MoreThanIP Marvell 10/100/1000 Ethernet daughter card that can be stuck on the dev board. I'm looking for docume...
16 years agoThen you probably have a GMII or RGMII interface between the PHY and the MAC. The schematics from the daughter card should help you find out wich one. The GMII interface uses 8 bits in each direction, whereas the RGMII uses 4.
