14 years agoTcp to Udp modifications
Hi, I'm working on Simple socket server example in which it uses tcp/ip...since I need high transmission speed without control flow... I'd like to use the udp/ip...what kind of modifications shoul...
14 years agoedit simple_socket_server.c file and write your own UDP code, disable the previous one completely.
