14 years agoTcp to Udp modifications
Hi, I'm working on Simple socket server example in which it uses tcp/ip...since I need high transmission speed without control flow... I'd like to use the udp/ip...what kind of modifications shoul...
14 years agoI think that this wikipedia page (http://en.wikipedia.org/wiki/bsd_socket) is a good start to learn how to use the API, and it shows the difference between UDP and TCP handling, from both the server and client sides.
Remember that with UDP you may loose packets, as you have no flow control or acknowledge mechanism.
