21 years agoTCP KEEP_ALIVE
Hi, Is there a restriction on the TCP stack on the use of KEEP_ALIVE option ? I didn't success in using this option : There is no error message, but I can't see any additional exch...
21 years agoHi,
OK it works fine. The main difference with "standard" code that I could seen, is the need to set IPPROTO_TCP in the socket function call (instead of 0). For convenience, I give the final code that works fine : <div class='quotetop'>QUOTE </div> --- Quote Start --- if ((fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP)) < 0) { TRACE_CONNECT "Error : cannot create the control socket\n"); return -1; } /* Set options of that socket */ sockval = TCP_KEEPIDLE_VALUE; if (setsockopt (fd, SOL_TCP, TCP_KEEPIDLE, (void *)&sockval, sizeof(sockval)) == -1) { TRACE_CONNECT "Warning : TCP_KEEPIDLE option set failed\n"); } sockval = TCP_KEEPCNT_VALUE; if (setsockopt (fd, SOL_TCP, TCP_KEEPCNT, (void *)&sockval, sizeof(sockval)) == -1) { TRACE_CONNECT "Warning : TCP_KEEPCNT option set failed\n"); } sockval = TCP_KEEPINTVL_VALUE; if (setsockopt(fd, SOL_TCP, TCP_KEEPINTVL, &sockval, sizeof(sockval)) == -1) { TRACE_CONNECT "Warning : TCP_KEEPINTVL option set failed\n"); } sockval = SO_KEEPALIVE_VALUE; if (setsockopt(fd, SOL_SOCKET, SO_KEEPALIVE, &sockval, sizeof(sockval)) == -1) { TRACE_CONNECT "Warning : KeepAlive option set failed\n"); } /* Permanent try of connection */ while (1) { memset(&adsock_server, 0, sizeof(adsock_server)); adsock_server.sin_family = AF_INET; adsock_server.sin_port = htons(TCPPort); adsock_server.sin_addr.s_addr = htonl(IPAddress); if (connect(fd, (struct sockaddr *)&adsock_server, sizeof(adsock_server)) == -1) { TRACE_CONNECT "Warning : connection to server failed\n"); }[/b] --- Quote End ---
