14 years agoTarget processor not responding.
Hello. I'm trying to use SDRAM controller with DE2-70 board (SDRAM chip is IS42S16160B): Bits: 16 CS: 1 Banks: 4 Row/Col:13/9 Timing settings from datasheet: http://i43.tinypic.com/2rd...
14 years agoI don't think the JTAG debug/uart can run that fast.
You might need to feed a slower clock into the debug module so that it is accesses through a clock crossing bridge. There may also be other timing issues - running at 150MHz needs the timinga analysis be done correctly.
