9 years ago"Taking the SDRAM bridge out of reset"
Hello everyone, (using DE0-Nano-SoC w/ Cyclone V SoC) First of, I am relatively new to SoC design and to working with Altera products. I am trying to accomplish a project where I am moving da...
9 years agoI stumbled across this explanation, https://www.altera.com/support/support-resources/knowledge-base/embedded/2016/how-and-when-can-i-enable-the-fpga2sdram-bridge-on-cyclone-v-soc.html?utm_source=altera&utm_medium=newsletter&utm_campaign=facts&utm_content=na_how_can_i_enable_ki_15_08_2016
adding "run bridge_enable_handoff" to the u-boot should take care of it when using SoCEDS13.1 or newer. EDIT: RUNNING ONLY THE BRIDGE_ENABLE_HANDOFF WILL NOT WORK IN SOME CASES. PLEASE REFER TO: http://www.alteraforum.com/forum/showthread.php?t=51200 THIS WORKED FOR ME! a small remark on what is mentioned in this topic; I ran :setenv fpga2sdram_handoff 0x311
saveenv
run bridge_enable_handoff After this i programmed the FPGA and booted linux. after this i was able to use the F2S port to write to SDRAM I also added these lines to my u-boot.scr
