9 years agoSupress Eclipse command "gdb-set auto-solib-add"
I have a remote connection to a target running a nios2 processor with uClinux distribution over TCP/IP under the control of Eclipse-CDT. nios2-linux-uclibc-gdb debugger doesn't support set auto-solib...
9 years ago --- Quote Start --- nios2-linux-uclibc-gdb debugger doesn't support set auto-solib-add command. --- Quote End --- It seems that nios2-linux-uclibc-gdb is based on GNU gdb version 6.1 which doesn't support the auto-solib-add option. How can I compile a new version of nios2-linux-uclibc-gdb based on GNU gdb 7.x ? Any suggestion would be very much appreciated? Many thanks. eclipse-cdt: mars
quartus 10.1 debugger: nios2-linux-libc-gdb version 6.1
