Sitanshu_N_Intel
7 years agoStructure/enum alignment
Do we need to provide a 32 bit number for the last entity of the enum? in order to get it aligned to word boundary?
I see that if this entry is not present then I see corruption for variables before or after.
- JOHI
Contributor
The Pragma PACK directive can be of service in your case.
However, can you provide an example of your code to clarify your issue.
A rogue pointer is more likely to be the cause of your trouble.
Johi.
- Ahmed_H_Intel1
Hi Sitanshu, I think so, you have to provide a 32 bit number. Can you share a sample code to check what you are tring to do?
