14 years agoStrange problem with IORD_16DIRECT
Hi, I have a 16-bit pio (input) in my sopc and I want to access the data through IORD_16DIRECT. The data shown on the port is 0x00, 0x01, 0x02....0xff (verified through signaltap). However, th...
14 years agoIs your pio returning the next value on each read request?
Are you decoding the address lines properly? Although you are using IORD_16DIRECT() the bus cycle requested by the nios cpu will be a 32bit one (with all byte enables asserted). Since your slave is 16bit it will see 2 read cycles, one for address 0 and one for address 2 (not sure what the address line is called by then! - might be A0 relative to your slave). In practise it is best to use 32bit slaves and set the high bits to zero on reads.
