14 years agoStarting point for DE1 Board
Hi all, Recently i have buy the Altera DE1 Board. My objectif is to make a projects with Nios II F and all the things with a commented source for everyone want to start a project with DE1 and...
14 years agoYou're just creating nets that don't connect anywhere. They're not connected to any pins.
You need to connect them to the VGA ports defined in your top level module. That is, instead of R, connect it to VGA_R, instead of sync_n, connect to VGA_SYNC_N, etc. If you look at your top level module, you can find in the port declarations all the ports you didn't connect to :
//////////////////////// VGA ////////////////////////////
output VGA_HS; // VGA H_SYNC
output VGA_VS; // VGA V_SYNC
output VGA_R; // VGA Red
output VGA_G; // VGA Green
output VGA_B; // VGA Blue
output VGA_CLK; // VGA Clock
output VGA_BLANK; // VGA Blank
output VGA_SYNC_N; // VGA Sync
output VGA_SYNC_T; // VGA Sync
output VGA_M1; // VGA M1
output VGA_M2; // VGA M2
