10 years agoStandard stdout through JTAG
I am interested in build the following environment through Nios II. Through a proper Qsys system, i.e., JTAG included, it is possible to use printf commands to be echoed in the Nios Console. ...
10 years agoI'm not sure what you are referring to and what is different for you between "via debug" and "run directly" ?
The host filesystem is using the debugger / JTAG to do the communication that happens during the file operations, so you can't ever run it without being connected and running through the debugger.
