14 years agoSSS Task Never Starting
I am attempting to run the simple socket server (RGMII) on my custom board. I have run a memory test and verified all of my SDRAM is working and the SSS design is using the same hardware and configur...
14 years ago --- Quote Start --- Does the scheduler start correctly? Do you have a system timer component in your system and is it working? The scheduler will freeze if the system timer doesn't generate any interrupts. --- Quote End --- How can I tell if the scheduler starts correctly and what would cause it to not start correctly? I have two interval timers in my design, one for each clock speed. The main one is 75 MHz, timeout is 10 us. It appears to be generating interrupts because if I suspend the process in debug it's almost always servicing that interrupt.
