14 years agoSSS Task Never Starting
I am attempting to run the simple socket server (RGMII) on my custom board. I have run a memory test and verified all of my SDRAM is working and the SSS design is using the same hardware and configur...
14 years agoDoes the scheduler start correctly?
Do you have a system timer component in your system and is it working? The scheduler will freeze if the system timer doesn't generate any interrupts.
