17 years agoSSH broken
Under Customize Application/Library Settings
Network Applications --> [*] ssh [*] sshd [*] ssh-keygen I also enabled syslog BusyBox --> [*] System logging utilities --> [*] SysLogD I created a simple /etc/sshd_config file that set the port to 22 (default). I did this because sshd generated an error if there was no config file. I created a host key using ssh-keygen on the nios2 hardware but it was unrecognized as a valid key file. So I generated it on my Linux PC and copied it into the nios2 board. I started the daemon and verified that it was running using ps. Then I ran netstat -tanl do verify that the ssh daemon was listening on port 22. Unfortunately it was not. Looking at the log file it appears that everything was Ok until the very end when I get a "bad protocol" message. The log is included below. Any help with this would be much appreciated. Thanks, Alex Nov 30 00:25:27 HALFDOME_A9 auth.debug sshd[43]: debug2: load_server_config: filename /etc/sshd_config Nov 30 00:25:27 HALFDOME_A9 auth.debug sshd[43]: debug2: load_server_config: done config len = 20 Nov 30 00:25:27 HALFDOME_A9 auth.debug sshd[43]: debug2: parse_server_config: config /etc/sshd_config len 20 Nov 30 00:25:27 HALFDOME_A9 auth.debug sshd[43]: debug3: /etc/sshd_config:1 setting port 22 Nov 30 00:25:27 HALFDOME_A9 auth.debug sshd[43]: debug3: /etc/sshd_config:2 setting protocol 2 Nov 30 00:25:27 HALFDOME_A9 auth.debug sshd[43]: debug1: sshd version OpenSSH_4.7p1 Nov 30 00:25:27 HALFDOME_A9 auth.debug sshd[43]: debug3: Not a RSA1 key file /etc/ssh_host_rsa_key. Nov 30 00:25:27 HALFDOME_A9 auth.debug sshd[43]: debug1: read PEM private key done: type RSA Nov 30 00:25:27 HALFDOME_A9 auth.debug sshd[43]: debug1: private host key:# 0 type 1 RSA Nov 30 00:25:27 HALFDOME_A9 auth.debug sshd[43]: debug3: Not a RSA1 key file /etc/ssh_host_dsa_key. Nov 30 00:25:27 HALFDOME_A9 auth.debug sshd[43]: debug1: read PEM private key done: type DSA Nov 30 00:25:27 HALFDOME_A9 auth.debug sshd[43]: debug1: private host key:# 1 type 2 DSA Nov 30 00:25:27 HALFDOME_A9 auth.debug sshd[43]: debug1: inetd sockets after dupping: 3, 4 Nov 30 00:25:27 HALFDOME_A9 auth.info sshd[43]: Connection from UNKNOWN port 65535 Nov 30 00:25:32 HALFDOME_A9 auth.info sshd[43]: Bad protocol version identification '' from UNKNOWN8 Replies
I've had better luck using Dropbear (both server and client) versus OpenSSH (just the client). You might give it a go...
Cheers, - slacker - Altera_Forum
Slacker may be correct that Dropbear is a better solution. I plan to look at that at some point . I did manage to get ssh working.
First it seemd that in a uClinux environment the ssh daemon expects to be launched from inetd. So I modified the ssh makefile in uClinux-dist/user/ssh to add a line in the inetd.conf file to launch the Daemon. $(ROMFSINST) -e CONFIG_USER_SSH_SSHD -a "ssh stream tcp nowait root /bin/sshd -i" /etc/inetd.conf I am using a simple sshd_config file: Port 22 Protocol 2 AddressFamily inet I generated the host keys on my PC Linux workstation and copied them into the jffs2 file system. The RC file copies them into the /etc directory. Not very efficient. To start an ssh session from my workstation on the nios2 target I type: ssh -x -l root -T <IP ADDRESS> As mentioned in the initial post, I enabled the three ssh utilities in Network Applications. I did not need to explicitly enable ssl. There was some documentation around that indicated that it was needed. If so it is picked up automatically. Alex - Altera_Forum
That seems like a really good enhancement.
Could you create a patch from this and send it to hippo so that he can include it in the standard distr ? Thanks, -Michael - Altera_Forum
Michael, I am more than happy to create a patch for the makefile. I am also currently working on the I2C/RTC problem (another active thread on this forum). Could you please point me at the instructions/method for sending the patch to hippo (I have no email address for him) and also is there something for contributing to the wiki? I am thinking a wiki entry for setting up the RTC would be nice too. Thanks, Alex - Altera_Forum
Hi halfdome,
Please subscribe nios2-dev mailing list and git-send-email to the list. http://sopc.et.ntust.edu.tw/cgi-bin/mailma...tinfo/nios2-dev (http://sopc.et.ntust.edu.tw/cgi-bin/mailman/listinfo/nios2-dev) I have ds1307/ds1338 worked on NEEK. Please see the wiki, http://www.nioswiki.com/gpio (http://www.nioswiki.com/gpio) Cheer, Hippo - Altera_Forum
<div class='quotetop'>QUOTE (hippo @ Aug 5 2009, 04:29 AM) <{post_snapback}> (index.php?act=findpost&pid=23414)</div>
--- Quote Start --- I have ds1307/ds1338 worked on NEEK. Please see the wiki, http://www.nioswiki.com/gpio (http://www.nioswiki.com/gpio)[/b] --- Quote End --- - Is there a cause why, on the NEEK hardware, bit baning on a GPIO port is implemented instead of using some I²C ipCore ? - Does this I²C interface-driver support an I²C "subsystem" so that I²C "chip driver" Kernel modules can be created that use these hardware pins as a common bus for multiple different I²C enabled chips ? -Michael - Altera_Forum
<div class='quotetop'>QUOTE (mschnell @ Aug 5 2009, 03:19 PM) <{post_snapback}> (index.php?act=findpost&pid=23416)</div>
--- Quote Start --- <div class='quotetop'>QUOTE (hippo @ Aug 5 2009, 04:29 AM) <{post_snapback}> (index.php?act=findpost&pid=23414) --- Quote End --- --- Quote Start --- I have ds1307/ds1338 worked on NEEK. Please see the wiki, http://www.nioswiki.com/gpio (http://www.nioswiki.com/gpio)[/b] --- Quote End --- - Is there a cause why, on the NEEK hardware, bit baning on a GPIO port is implemented instead of using some I²C ipCore ? - Does this I²C interface-driver support an I²C "subsystem" so that I²C "chip driver" Kernel modules can be created that use these hardware pins as a common bus for multiple different I²C enabled chips ? -Michael [/b] --- Quote End --- GPIO is simple, low LE count and easy to debug. Bit banging i2c is used on almost every PC. Unless you will have high i2c traffic, gpio i2c is the better choice in term of LE usage. There is no difference in 2c chip drivers, other than the the low level interface. You can have multiple i2c devices on a i2c bus. Each device usually have wired i2c address. On neek, there are three independent i2c buses. Beside kernel i2c chip drivers, user space drivers through /dev/i2c-x are also supported, such as i2c-tools utility. Cheer, Hippo - Altera_Forum
Sounds good !
Thanks ! -Michael
