21 years agoSPI Slave bug?
Has anybody used the SPI core as a slave device in a NIOS II implementation? If so, have you had relatively frequent data errors? There is no HAL for the SPI as slave, so I'm just using th...
14 years ago --- Quote Start --- SOPC bilder generates, as seems, wrong verilog code for SPI slave, at SS_n rise edge rx register shifted one more time, and ROE bit is set to 1. To avoid this, you should read RX register before SS_n rise edge or delay SS_n edge, if it possible. --- Quote End --- Could you elaborate on this? Also, is Altera going to fix this bug?
