21 years agoSPI Slave bug?
Has anybody used the SPI core as a slave device in a NIOS II implementation? If so, have you had relatively frequent data errors? There is no HAL for the SPI as slave, so I'm just using th...
15 years agoSOPC bilder generates, as seems, wrong verilog code for SPI slave, at SS_n rise edge rx register shifted one more time, and ROE bit is set to 1. To avoid this, you should read RX register before SS_n rise edge or delay SS_n edge, if it possible.
