21 years agoSPI Slave bug?
Has anybody used the SPI core as a slave device in a NIOS II implementation? If so, have you had relatively frequent data errors? There is no HAL for the SPI as slave, so I'm just using th...
16 years agoI use the SOPC-Builder to build my project. You can find that module in the SOPC-Builder Library under "Interface Protocols" -> "Serial" -> "SPI (3 Wire Serial)".
Or, you may find it in your install directory: <root>/altera/<version>/ip/altera/sopc_builder_ip/altera_avalon_spi/
