14 years agoSPI Problems
Hi, I'm trying to get handle with the SPI on a Nios II Core but I don't get it. I have a SPI master and a SPI Slave that I can try to transmit some data from the master to the slave. I connecte...
14 years agoHi chris 72,
thanks for your support! I tried what you`ve told me and also control the pin assignment for the loopback board. For this I used the loopback_test_lowcost.pdf from Altera. My assignment looks like it is benife: spi_master_MISO,Input,PIN_Y4 spi_master_MOSI,Output,PIN_R6 spi_master_SCLK,Output,PIN_R7 spi_master_SS_n,Output,PIN_V3 spi_slave_MISO,Output,PIN_V4 spi_slave_MOSI,Input,PIN_AB1 spi_slave_SCLK,Input,PIN_AB2 spi_slave_SS_n,Input,PIN_Y3 I also tested to connect the MOSI of the Master to a LED on the board but I can't see anything. Maybe it is because of the frequency:). The frequency of my system is 50MHZ and the frequency for the SPI is 128kHZ. could this be a problem? I also looked through the Controlregs and the Statusregs of the Spi: Befor transmitting data: Statusregister of the Master: 0x260.(1001100000) Controlregister of the Master: 0x400.(10000000000) Statusregister of the Slave: 0x310.(1100010000) Controlregister of the Slave: 0x0(0) After transmitting and reading data: Statusregister of the Master: 0x260.(1001100000) Controlregister of the Master: 0x0.(0) Statusregister of the Slave: 0x310.(1100010000) Controlregister of the Slave: 0x0.(0) I thank you in advance for your help!
