11 years agoSPI from HPS through FPGA not working
Hello, Since 6 month i am working with SOC Cyclone V Evalboard from Altera. I use Yocto to build linux and EDS V 14.0 for development. For Knowledge and HowTo my first place is Rocketboa...
11 years agoAll works.
root@socfpga:~# ./mem 0xfff00008 data = 0x00000001 root@socfpga:~# ./mem 0xfff00008 0 ;disable root@socfpga:~# ./mem 0xfff00010 1 ;cs 0 root@socfpga:~# ./mem 0xfff00014 100 ; clock &per_base_clk / 100 root@socfpga:~# ./mem 0xfff00000 0xcf ; cpol cpha 16-bit root@socfpga:~# ./mem 0xfff00008 1 ; enable root@socfpga:~# ./mem 0xfff00060 ;read data = 0x00000000 root@socfpga:~# ./mem 0xfff00060 256 ;write root@socfpga:~# ./mem 0xfff00028 ;status data = 0x0000000e ; RX not empty... root@socfpga:~# ./mem 0xfff00024 ;rx data count data = 0x00000001 root@socfpga:~# ./mem 0xfff00060 ;read data = 0x0000040a In QSYS SPI clock 100MHz ... .hps_0_spim0_txd (temp_mosi), //mosi hps_0_spim0.txd .hps_0_spim0_rxd (temp_miso), //miso .rxd .hps_0_spim0_ss_in_n (), // .ss_in_n .hps_0_spim0_ssi_oe_n (), // .ssi_oe_n .hps_0_spim0_ss_0_n (temp_cs_n), // .ss_0_n .hps_0_spim0_ss_1_n (), // .ss_1_n .hps_0_spim0_ss_2_n (), // .ss_2_n .hps_0_spim0_ss_3_n (), //sck .ss_3_n .hps_0_spim0_sclk_out_clk (spi_sck) /**/ ); /**/ wire spi_sck; assign temp_sclk=spi_sck & hps_fpga_reset_n; hps_0_spim0: spi@0xfff00000 { compatible = "snps,dw-spi-mmio-14.1", "snps,dw-spi-mmio"; reg = < 0xFFF00000 0x00000100 >; interrupt-parent = < &hps_0_arm_gic_0 >; interrupts = < 0 154 4 >; # address-cells = < 1 >; /* embeddedsw.dts.params.#address-cells type NUMBER */ # size-cells = < 0 >; /* embeddedsw.dts.params.#size-cells type NUMBER */ bus-num = < 0 >; /* embeddedsw.dts.params.bus-num type NUMBER */ num-chipselect = < 1 >; /* embeddedsw.dts.params.num-chipselect type NUMBER */ status = "okay"; /* embeddedsw.dts.params.status type STRING */ clocks = < &per_base_clk >; /* appended from boardinfo */ spidev0: spidev@0 { compatible = "spidev"; /* appended from boardinfo */ reg = < 4293918720 >; /* appended from boardinfo */ spi-max-frequency = < 100000000 >; /* appended from boardinfo */ enable-dma = < 1 >; /* appended from boardinfo */ }; //end spidev@0 (spidev0) }; //end spi@0xfff00000 (hps_0_spim0)
