SAN's avatar
SAN
8 years ago
SPI Communication with STM32 Discovery Board(Master) and Nios(Slave)
First, I'm not good at English. Sorry.
I want to SPI communication with STM32(master)​ and Nios System(slave).
The protocol receives a 3-byte command data and transfers 512-byte data. (slave)
​Slave must transfer 512 Bytes of Data to Master​.
​I use SPI(3 Wire Serial) IP and confirm 1Byte receive&transmit.
But, the slave not received 3-byte. Sometimes it is overwritten and only the last byte is read.
​Rx interrupt handler code is
void SPI_RX_Interrupt_Handler(void * context){
alt_u32 status;
alt_u32 control;
// Disable Interrupt
IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_BASE, 0);
/* Keep clocking until all the data has been processed. */
for ( ; ; )
status = IORD_ALTERA_AVALON_SPI_STATUS(SPI_BASE);
if((status & ALTERA_AVALON_SPI_STATUS_ROE_MSK) != 0)
IOWR_ALTERA_AVALON_SPI_STATUS(SPI_BASE, 0);
continue;
if ((status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) != 0)
alt_u32 rxdata = IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE);
rxData[rx_counter] = (alt_u8)rxdata;
rx_counter++;
if(rx_counter > 3)
rx_complete = 1;
break;
qsys capture file is attach.
I use Cyclone IV device and SPI CLK is 3Mbits/s(STM Board setting).​
So, My question is
  • Is it right to use SPI(3 Wire Serial) IP?
    • if so, do i need an additional FIFO Buffer or any other IP?
    • if not, please recommand IP.
  • ​Can the slave use the SPI Command API(altera_avalon_spi.h)?
    • if so, i will thank you and tell how to use them.
​Thank you for reading.
