15 years agoSPI and uClinux
Hi all, I have a design in which I have to use SPI in order to communicate with an external PIC. I find that it is not enough to select SPI driver in uClinux kernel configuration because when I...
14 years agoHi again,
I found that there is an error in drivers/base/platform.c. Error code is ENODEV (dsl you were right).
int __init_or_module platform_driver_probe(struct platform_driver *drv,
int (*probe)(struct platform_device *))
int retval, code;
/* temporary section violation during probe() */
drv->probe = probe;
retval = code = platform_driver_register(drv);
/* Fixup that section violation, being paranoid about code scanning
* the list of drivers in order to probe new devices. Check to see
* if the probe was successful, and make sure any forced probes of
* new devices fail.
spin_lock(&platform_bus_type.p->klist_drivers.k_lock);
//drv->probe = NULL; Commented by me
if (code == 0 && list_empty(&drv->driver.p->klist_devices.k_list))
retval = -ENODEV;
drv->driver.probe = platform_drv_probe_fail;
spin_unlock(&platform_bus_type.p->klist_drivers.k_lock);
if (code != retval)
platform_driver_unregister(drv);
return retval;
I think the error is due to "list_empty" that should returns 0 but returns 1. Am I right? Am i right when I comment drv->probe = NULL? What else should I do?
