15 years agoSPI and uClinux
Hi all, I have a design in which I have to use SPI in order to communicate with an external PIC. I find that it is not enough to select SPI driver in uClinux kernel configuration because when I...
14 years ago --- Quote Start --- Hi neolux, thanks for your answer :-) I followed these steps, but it didn't work. After platform_driver_probe in altera_spi_init it returns -19, so there's an error. How can i fix it?Where can I find the error code list? --- Quote End --- knowing error code doesn't help much. go to spi_altera.c put printk before all returns and verify why and where it is returning. You can go further if required.
