15 years agoSPI and uClinux
Hi all, I have a design in which I have to use SPI in order to communicate with an external PIC. I find that it is not enough to select SPI driver in uClinux kernel configuration because when I...
14 years agoOk, reading documentation in Linux kernel I find that if I want to use open() and write() function within my software I need to write a protocol driver or simply use spidev driver. I added in config.c the following code
static struct spi_board_info nios2_spi_devices = {
.modalias = "spidev",
.max_speed_hz = 173.3 * 1000,
.bus_num = 1,
.chip_select = 0,
.irq = na_spi_irq,
.mode = SPI_MODE_0,
and I did what is described in spidev documentation, but I am still not able to have spidev1.0 in /dev directory. Can anyone help me?
