15 years agoSPI and uClinux
Hi all, I have a design in which I have to use SPI in order to communicate with an external PIC. I find that it is not enough to select SPI driver in uClinux kernel configuration because when I...
15 years agoHi liunx, thanks for your reply. Attached and below you can find the information you asked for.
--- Quote Start --- Linux version 2.6.30 (marco@uClinux) (gcc version 3.4.6)# 404 PREEMPT Tue Oct 11 17:44:02 CEST 2011 uClinux/Nios II Built 1 zonelists in Zone order, mobility grouping off. Total pages: 32512 Kernel command line: NR_IRQS:32 PID hash table entries: 512 (order: 9, 2048 bytes) Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Memory available: 126552k/3382k RAM, 0k/0k ROM (1879k kernel code, 1502k data) Calibrating delay loop... 61.64 BogoMIPS (lpj=308224) Mount-cache hash table entries: 512 net_namespace: 264 bytes NET: Registered protocol family 16 init_BSP(): registering device resources bio: create slab <bio-0> at 0 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 4096 (order: 3, 32768 bytes) TCP bind hash table entries: 4096 (order: 2, 16384 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP reno registered NET: Registered protocol family 1 JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. JFFS2: default compression mode: priority io scheduler noop registered io scheduler deadline registered (default) ienable reg:100 ienable reg:108 pio_fpga_in - s ttyJ0 at MMIO 0x8004d50 (irq = 1) is a Altera JTAG UART console [ttyJ0] enabled ttyS0 at MMIO 0x8004c80 (irq = 7) is a Altera UART ttyS1 at MMIO 0x8000000 (irq = 6) is a Altera UART SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256). 0 : New Bus ID BUG: No TSE MDIO Reset Altera TSE MII Bus: probed Found phy with ID=0x1410cc2 at address=0x12 Altera TSE MII Bus: MDIO Bus Registered eth0 (): not using net_device_ops yet eth0:Successed to register TSE net device Altera Triple Speed MAC IP Driver(v8.0) developed by SLS,August-2008,--Linux 2.6 .27-rc3 physmap platform flash device: 04000000 at 0c000000 physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank Amd/Fujitsu Extended Query Table at 0x0040 physmap-flash.0: CFI does not contain boot bank location. Assuming top. number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using physmap partition information Creating 9 MTD partitions on "physmap-flash.0": 0x000000000000-0x000002800000 : "userspace" 0x000002800000-0x000002900000 : "U-Boot" 0x000002900000-0x000002d00000 : "uImage1" 0x000002d00000-0x000003100000 : "uImage2" 0x000003100000-0x000003500000 : "uImage3" 0x000003500000-0x000003880000 : "DEFAULT_MMU" 0x000003880000-0x000003c00000 : "MAXIMUM_MMU" 0x000003c00000-0x000003f80000 : "USER_IMAGE" 0x000003f80000-0x000003fa0000 : "options-bits" TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. Freeing unused kernel memory: 772k freed (0x1028c000 - 0x1034c000) Shell invoked to run file: /etc/rc Command: hostname uClinux Command: mount -t proc proc /proc -o noexec,nosuid,nodev Command: mount -t sysfs sysfs /sys -o noexec,nosuid,nodev Command: mount -t devpts devpts /dev/pts -o noexec,nosuid Command: mkdir /var/tmp Command: mkdir /var/log Command: mkdir /var/run Command: mkdir /var/lock Command: mkdir /var/empty Command: ifconfig lo 127.0.0.1 Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo Command: ifconfig eth0 hw ether 00:07:ED:11:80:c9 Command: ifconfig eth0 192.168.100.229 Command: route add default gw 192.168.100.1 Command: mount -t jffs2 /dev/mtdblock0 /mnt Command: inetd& [28] Command: cat /etc/motd Welcome to ____ _ _ / __| ||_| _ _| | | | _ ____ _ _ _ _ | | | | | | || | _ \| | | |\ \/ / | |_| | |__| || | | | | |_| |/ | ___\____|_||_|_| |_|\____|\_/\_/ | | |_| For further information check: http://www.uclinux.org/ Sash command shell (version 1.1.1) /> --- Quote End ---
