14 years agospeex encoder on nios 2
Hi, I'm trying to port Speex encoder unit on a Nios 2 system. I managed to compile the code and upload it to the device. The only thing is that, using either the floating point or the fixed poi...
14 years agoI also thought that the problem is in the memory size(stack overflow) but then I encountered another problem.
The actual structure of the nios is cpu+pio+jtag+uart+onchip memory (4kB ) used for reset and exception vector + onchip memory (256 kB ) for code and data. If I try to modify the size of the second RAM ( +/-) or if I try to use the external RAM I get the "verify failed" error when uploading the code.
