14 years agospeex encoder on nios 2
Hi, I'm trying to port Speex encoder unit on a Nios 2 system. I managed to compile the code and upload it to the device. The only thing is that, using either the floating point or the fixed poi...
14 years agoCurrently I'm working on the fixed point version, but, as I wrote before, the differences exist on this version to. I have some problems following the code-line, because I have little experience in this job-line ( in this moment I can't say for sure that I identified correctly the main encoding function, or if that encoding function is the first function called in the encoding routine , because they are using pointers to functions).
