16 years agoSome NIOS FPGA help please?
Hello there People of the Altera forum!
Could anyone advise me on how to go about setting up php/mysql on the NIOS II Cyclone II development kit, I have the webserver running, but I would just like to know whether or not it is actually possible to have PHP installed or not. Also as I am kinda new to this, could anyone tell me how the html or even the index.html file gets generated please. I have a feeling as it is generated during compile time into the uncompress zip file, but I would just like to know where the html is kept and if its possible to edit the code after compile time. Thank you, MRb6 Replies
I don't think either mysql or php have been ported to the Nios platform, and IMHO it is a difficult task. Using Linux instead of uCOS might help.
Hi there Daixiwen,
Thank you for the reply. I have since decided to not try a php install in this project, no need to over complicate things. And I have no idea how to use linux - I have been using windows since 3.1 came out ;-p though linux is more stable, I am just simply stuck in my ways of a familiar GUI. For now I just need to put custom web content into the read only zip file and get that onto the flash device. Basically just some simple links & open & display text files etc on the screen, then possibly expand this to holding hex files for use in pic re-programming, whether this is possible or not though I am not sure, it's just a long term option that I am looking at for doing software upgrade's to IC's/MCU's over the internet or intranet from the Ethernet port. All good fun learning though! Any further advice or pointer's would be welcome. Cheers, MRb - Altera_Forum
When you start the web server, the bottom of the page has some hint for you to create your own web server.
In your project directory, there are a few interesting files - ReadMe.txt - ro_zipfs.zip - web_server.c/.h - http.c/.h - and all other *.c /*.h (1) ReadMe.txt Read the "ReadMe.txt" first, it has some text about this web_server project & little explain on each important c & h file. (2) ro_zipfs.zip It is just a zip file, without compression, consist of index.html, and several html pages and pictures. Modify it to suite your web page need, and zip it without compression. (3) web_server.c web_server.c is where the main() define (4) http.c http.c define the mapping from the web page HTML "POST" request to the actual function call in http.c Look at - "post_funcs" that define the mapping struct at http.c line 110, - "sweep_field" declaration that map HTML POST "/SWEEP" at http.c line 336 - and index.html method=post action="/SWEEP" declaration - The function that you need will be very similar to the "choose" & "upload" button and the program_flash.html in the zip file. - Altera_Forum
If you have the NEEK board, there are a lot more interesting web_server project available on web.
Load web page from SD-Card formatted to "FAT" file system _www_.altera.com/support/examples/nios2/exm-micro_tutorial.html_ Web server With AJAX support _www_.nioswiki.com/ExampleDesigns_ - Altera_Forum
Hi there Kee020041,
Thank you for such an informative post! Just what I needed to see ;-p I have spent majority of today trying to decipher the web_server.c, so this has helped a lot, I'll admit I'm kinda out of my depth here, but that's called learning I guess! Thanks for the links too, especially If I can go read/write It will make a lot of difference, I can't wait to have a mess with the AJAX stuff, I use that with some of the php/mysql stuff I do as a side project. Again, thanks for the advice, If I have any more issues/questions I will post again for help. Cheers, MRb - Altera_Forum
Im trying to run the web server example on the DE2-115 using NIOS II IDE. I am changing the code according to my project. However, I need to know how to let the user change the switches (SW0-SW17) on the board, then make the changes appear on the web page when i open it such that the webpage is automatically refreshed to capture any changes in the switches. Any idea?! Help?! Thank you in advance!!!
