14 years agoSoftware Driver for Qsys Subsystem
Does anyone know a way to include software into a BSP for a QSys subsystem? I frequently have SOPC systems which contain multiple components which serve a single function (for example, a chai...
14 years agoOr just define the hardware register layout in a .h file of your own - exactly the same way as you would if writing a driver for a physical device.
The only thing you really need from the SOPC system is the base address - and if your projects are reasonably similar you can probably use a common(ish) base address. The 'automatic' base address assigments I've seen failed to partition the devices into sane groupings - much easier for debug (etc).
