14 years agosoc...please help, is simple!!!!!!!!!!!!!!!!!!!!!
Hi, someone could help me? I designed the nioss with sopcbuilder, code with eclipse, hardware ad-hoc with Quartus. Now how can I simulate it all together? I tried to add my vhdl cod...
14 years ago --- Quote Start --- Now, okay? If I wrote on the forum of course I did not find anything on google do not you think? --- Quote End --- I think you didn't look too hard, here are some resources From your other forum post...(admittedly this was not there before your first post here, but it was here before your reply here...but since it was a response to your post, I would think you should look there as well before posting again...apparently not) http://www.alteraforum.com/forum/showthread.php?t=33560 Google has a few good search results here that have been there all along which is why I suggested that you look. It's not hard, just Google the error message that you're getting. http://lmgtfy.com/?q=warning%3a+(vsim-3473)+component+instance+is+not+bound. In particular, the following link from the Google search looks helpful...once you open the link search for 'bound' http://users.ece.gatech.edu/~leehs/ece3055/homework/modelsim_tut.pdf --- Quote Start --- If you know the answer, tell me, otherwise goodbye, how were you forced to respond? --- Quote End --- I did tell you the answer...you posted twice, don't you remember? I was simply suggesting that you could get answers more quickly by doing the search yourself. If you choose to not be productive, that's OK too. Let's see now. I gave you the answer in one place; in another place I suggested where you could go to find that answer and I showed you how to get answers for yourself for future questions that you may have...but apparently that wasn't sufficient for you. --- Quote Start --- Who are the champion of justice alters the forum? --- Quote End --- I don't know who the champions of justice are...Superman? Are you upset that you posted to two different forums, looked in one that didn't have the answer directly but suggested where to look to find that answer and now you're upset? Kevin Jennings
