9 years agoSoC FPGA Ethernet Performance
Hi, I have application that needs to transfer 1 gigabit/s of data generated by the FPGA over Ethernet. FPGA generated data would be written to HPS's DDR3-memory. The data would be transferred o...
9 years agoMost of the limitation is on the SW side.
When talking 1Gbps using GigE, it's the raw bit rate of the Ethernet link. See maximum efficiency in https://en.wikipedia.org/wiki/ethernet_frame. In theory, 970Mbps is possible over GigE. The DMA itself can transfer at 1 Gbps: it uses linked lists of descriptors+buffer and these have to be maintained/monitored by the SW and that'is one of the bottle neck. Another bottle neck is for the processor to read the data / flush the caches, going across the L1 & L2 caches to access the external memory. This said, I am of the same opinion as flz47655 that you shouldn't have major problems getting 1Gbps using 2 GigE links. You may need to tweak a bit the SW and possibly dedicate one of the 2 cores for that. Regards
