14 years agoSimulating NiosII in Modelsim
I'am simulating a small Nios II System in with Modelsim. After starting the Simulator from the Eclipse, I use the command "s" in Modelsim to compile all HDL source code and to load the design. I use the command "w" to open the Wave window with "useful" signals. Now i can run my Design. My Question: What should i do to see the "OpCode" and the Nios Pipeline structure in Modelsim, like in the attached File ? Thanks, NicolasNo RepliesBe the first to reply
