14 years agoSimple Socket Server not responding
Hi, All, I'm a newbie in FPGA and embedded designs (and new to this forum as well). My system has a NIOS-II, TSE MAC, ETX PHY and external SSRAM. I've reached a point where the Simple Socke...
14 years agoHi, Daixien, Socrates,
-I'm using a static IP, as given in the example: 198.162.1.233, or something similar. The gateway is also 198.162.1.1 -Wireshark sees no incoming packets from the board, at all. -I'm trying to watch the stream interface with signaltap, but I see nothing: either my trigger is off (what should it be? the _write signal or the irq maybe?) or there is really no traffic on it, which might be the issue. If so, what can cause the stream interface to not work? I should point out that if i'm using the debugger, I can see the software reacting to incoming packets in the background. I just can't figure out what it see that causes it to ignore them... Thanks, Ran
