14 years agoSimple socket server example problem
Hi, I've a DE4-230 board...and I tried to test the simple socket server example. So i loaded on the fpga both the file.sof and the file.elf given with the board....in this case no problems...but ...
14 years agoyes, I solved it....as first thing....after you make modifications to Quartus2/Sopc program you have to re-generate the system...and insert the new .sopcinfo file in eclipse...then as regards SSS C-codes....effectively...two codes are different and so...it needs to modify the eclipse SSS template code...first of all the file led.c in which you find a rand() function instead of a counting up code for controlling 7-segments display...and then the file Simple Socket Server.c file in which you have to insert the MAC of your board manually.
ps: you could also try to change manually the two files led.c and SimpleSocketServer.c of template with those in Quartus2 cd-rom with the board.
