14 years agoSimple socket server example problem
Hi, I've a DE4-230 board...and I tried to test the simple socket server example. So i loaded on the fpga both the file.sof and the file.elf given with the board....in this case no problems...but ...
14 years agoI have the same board and the same problem.
The design seems to be very program (Quartus version) dependent. I think, it does not compile because the Quartus version is not the same as the one used by Terasic. If you find a way to compile it: please let me know! David
