16 years agosimple socket server connection established, but cannot ping/telnet
hello guys, I got a problem with simple socket server problem. I post similiar thread in dev kit forum, but no answer until now. I am thinking maybe I could get help from here. Thank you in ad...
14 years ago --- Quote Start --- You need to provide different clock to Marvell 88E1111 PHY Device for different speed 2.5MHz for 10mbps 25MHz for 100mbps 125MHz for 1000mbps You are able to transfer data at 100mbps because you are providing a clock of 25MHz to your PHY device --- Quote End --- How can I provide 125Mhz clock to PHY Device? Should I change something in sopcbuilder or the verilog code in Top-level file? In the circuit diagram of PHY Device, I can only find ENET_25MHZ and it is give to XTAL1 in 88E1111.
