16 years agosimple socket server connection established, but cannot ping/telnet
hello guys, I got a problem with simple socket server problem. I post similiar thread in dev kit forum, but no answer until now. I am thinking maybe I could get help from here. Thank you in ad...
14 years ago --- Quote Start --- If you fix your PC for 100mbps , then you must be able to send and receive data. May be your PHY device reqiure 2.5MHz for 10mbps, 25MHz for 100mbps and 125 MHz for 1000mbps and you are providing only 25MHz. Just fix your PC for 100mbps and try then let me know......... --- Quote End --- Hi,rahul Thank you really much, when I fix my pc for 100Mbps and connect the board and PC with a cross-over cable. I succeed!!! But I still have a problem. As my PHY is 88E1111, so if I want to use 1000Mbps, what should I do ? Thanks for your help.
