16 years agosimple socket server connection established, but cannot ping/telnet
hello guys, I got a problem with simple socket server problem. I post similiar thread in dev kit forum, but no answer until now. I am thinking maybe I could get help from here. Thank you in ad...
16 years agoI am having the same problem using the Cyclone III Starter Board (3c25) and the HSMC-NET Daughter card.
If I run the demo batch file (which installs the .sof and .elf file that came with the daughter card) then I can connect to the socket as shown in the tutorial. However if I compile the project myself (SOPC, then Quartus, then NIOS II EDS), it connects in the same way and the output on the NIOS console is identical, but I get no response when pinging the IP address and I cannot connect to the socket. I have tried this using Quartus and Nios versions 8, 9.1 and 10. Same results every time. Help please!!!!
