16 years agosimple socket server connection established, but cannot ping/telnet
hello guys, I got a problem with simple socket server problem. I post similiar thread in dev kit forum, but no answer until now. I am thinking maybe I could get help from here. Thank you in ad...
16 years agoI have the same problem with you,dubuging server weeks but without any result,have you find the selution ?
--- Quote Start --- hi SIELASER, thank you so much for reply. my client PC is configred as: static IP: 192.168.1.235 subnet: 255.255.255.0 Default gateway: 192.168.1.1 Board is configred as:# define IPADDR0 192# define IPADDR1 168# define IPADDR2 1# define IPADDR3 234# define GWADDR0 192# define GWADDR1 168# define GWADDR2 1# define GWADDR3 1# define MSKADDR0 255# define MSKADDR1 255# define MSKADDR2 255# define MSKADDR3 0 I used cross cable to connect them directly. I did 1. load sof to board(it is a timelimited file recated by QII) 2. from IDE, load server application by "run as Nios II hardware" after load and print info to IDE, the server is waitting there. Then I try to ping from pc command line, by ping 192.168.1.234 I found the RX light blink sometime, but TX is quiet. the server looks still waitting, nothing happen. after a while, ping is failed No, I didn't do any debug, no return from select() call, the sever is just waitting --- Quote End ---
