15 years agosigned division
Hi all,
I design a piece of hardware using simple division as shown in below: module divider (in1, in2, division, multiply); //parameter parameter DATA_WIDTH = 32; //Input input [DATA_WIDTH-1:0] in1; input [DATA_WIDTH-1:0] in2; //Output output [DATA_WIDTH-1:0] division; output [DATA_WIDTH-1:0] multiply; assign division = (in1/in2); assign multiply = in1*in2; endmodule It works fine with positive number, however when I try with in1=-2352, in2=-588, by right, (-2352/-588) = 2, i should get 2. But the simulation result gives me 0 instead. Besides, when I try with one of the input is positive number, in1=2352, in2=-588, by right, (2352/-588) = -2, i should get -2. But the simulation result gives me 0 instead. What is going wrong and how to overcome this problem? thanks in advance, regards, ty63 Replies
I can't see a signed type definition in your code. By Verilog specification, you're performing unsigned arithmetic, which would pretty explain the issue.
I'm quite new to verilog, could you please explain what is signed type definition?
alright, I google the signed type definition and I modify my code from
input [DATA_WIDTH-1:0] in1 ==> input signed [DATA_WIDTH-1:0] in1; Thank you FVM. The next question is : is this signed type definition synthesizable?
