12 years ago[Shell Script failled] EPCS based Remote System Update (RSU) example on BeMicro SDK
Good morning all,
I tried to build the example given at that address : http://www.alterawiki.com/wiki/epcs_based_remote_system_update_(rsu)_example_on_bemicro_sdk . It's an example of RSU for BeMicro. I have downloaded the 20120130_bemicro_sdk_epcs_rsu_11.1sp1.tgz (http://www.alterawiki.com/uploads/a/a6/20120130_bemicro_sdk_epcs_rsu_11.1sp1.tgz) file, extract it and execute the top_build_everything_ser.sh but I get a lot of errors : ERROR: File project_sources/demo_images/factory_hw.flash is absent. ERROR: File project_sources/demo_images/factory_sw.flash is absent. ERROR: File project_sources/demo_images/app_hw.base64 is absent. ERROR: File project_sources/demo_images/app_hw_sw1.base64 is absent. ... Can anyone try to build this example and tell me if you get the same problem ? I cannot figure out why I got this. Thank you. Flandroid9 Replies
I found why, I have the new version of Quartus and the exemple is for an old one.
While the name of the file implies (20120130_BeMicro_SDK_EPCS_RSU_11.1sp1.tgz) Altera ACDS 11.1sp1.
The link http://www.alterawiki.com/wiki/epcs_based_remote_system_update_%28rsu%29_example_on_bemicro_sdk States 'This example was created and tested with the Altera ACDS 11.0sp1 development tools.' I tried with both versions of tools, the installations of which take up as much bleedin' room as Siberia on my hard drive, and I still get the errors ERROR: File project_sources/demo_images/factory_hw.flash is absent. ERROR: File project_sources/demo_images/factory_sw.flash is absent. ERROR: File project_sources/demo_images/app_hw.base64 is absent. ERROR: File project_sources/demo_images/app_hw_sw1.base64 is absent. etc. etc. etc. Altera software 'quality assurance' by the look of it..... Unless anyone has any other ideas? - Altera_Forum
--- Quote Start --- Good morning all, I tried to build the example given at that address : http://www.alterawiki.com/wiki/epcs_based_remote_system_update_(rsu)_example_on_bemicro_sdk . It's an example of RSU for BeMicro. I have downloaded the 20120130_bemicro_sdk_epcs_rsu_11.1sp1.tgz (http://www.alterawiki.com/uploads/a/a6/20120130_bemicro_sdk_epcs_rsu_11.1sp1.tgz) file, extract it and execute the top_build_everything_ser.sh but I get a lot of errors : ERROR: File project_sources/demo_images/factory_hw.flash is absent. ERROR: File project_sources/demo_images/factory_sw.flash is absent. ERROR: File project_sources/demo_images/app_hw.base64 is absent. ERROR: File project_sources/demo_images/app_hw_sw1.base64 is absent. ... Can anyone try to build this example and tell me if you get the same problem ? I cannot figure out why I got this. Thank you. Flandroid --- Quote End --- I am seeing the same problem. Did you figure out why? I have Quartus II 13.0.. but I installed Quartus II 11.1 still have the same issue... - Altera_Forum
I have the same problem. Is it because I have a newer version of Quartus II (13.0) vs the required Quartus II (11.0) ???
I tried install the correct version of Quartus II. Still doesn't work. Anyone who can help?? Thanks
--- Quote Start --- I tried install the correct version of Quartus II. Still doesn't work. Anyone who can help?? Thanks --- Quote End --- I think I used a different example. Either that or I installed 11.0sp1 or 11.1sp1 to get it to work. A right royal headache. - Altera_Forum
--- Quote Start --- I think I used a different example. Either that or I installed 11.0sp1 or 11.1sp1 to get it to work. A right royal headache. --- Quote End --- Any chance you can share the example. I have exhausted all options. - Altera_Forum
--- Quote Start --- Any chance you can share the example. I have exhausted all options. --- Quote End --- I used AN603 and modded it into my design. See attached.
