16 years agoSGDMA descriptor list questions
I want to build a descriptor linked list to transfer data form memory to TSE MAC.If I build one descriptor there's no problem.If I build more than one descriptors no data was transfered.Is there anybody tell me why?
this is the code: alt_avalon_sgdma_register_callback(pM_Context->mac_mi.tx_sgdma, &sgdma_transmit_callback_function, ( ALTERA_AVALON_SGDMA_CONTROL_IE_GLOBAL_MSK |ALTERA_AVALON_SGDMA_CONTROL_IE_CHAIN_COMPLETED_MSK) pM_Context); for(i=0;i<ASYNC_TRANS_DESC_MAX;i++)//|| { printf("config descrip \n"); p_write = pM_Context->Frame_List.Pbuffer[pM_Context->Frame_List.rear]+pM_Context->Frame_List.offset; pM_Context->Frame_List.offset += pM_Context->Frame_List.packetsize; pM_Context->Frame_List.framesubnum++; //packet_length = pM_Context->Frame_List.packetsize; alt_avalon_sgdma_construct_mem_to_stream_desc(&pM_Context->Current_desc[i], // descriptor &pM_Context->Current_desc[i+1], // next descriptor (alt_u32 *)p_write, // read buffer location (pM_Context->Frame_List.packetsize), // length of the buffer 0, // reads are not from a fixed location 1, // start of packet is enabled for the Avalon-ST interfaces 1, // end of packet is enabled for the Avalon-ST interfaces, 0); // there is only one channel } alt_avalon_sgdma_do_async_transfer(pM_Context->mac_mi.tx_sgdma, pM_Context->Current_desc);2 Replies
for(tse_ptr->chain_loop = 0; tse_ptr->chain_loop < ALTERA_TSE_SGDMA_RX_DESC_CHAIN_SIZE; tse_ptr->chain_loop++)
{ tse_ptr->pkt_array[tse_ptr->chain_loop] = pk_alloc(ALTERA_TSE_PKT_INIT_LEN+4); if (!tse_ptr->pkt_array[tse_ptr->chain_loop]) /* couldn't get a free buffer for rx */ { dprintf("[tse_sgdma_read_init] Fatal error: No free packet buffers for RX\n"); tse_ptr->netp->n_mib->ifInDiscards++; return ENP_NOBUFFER; } // ensure bit-31 of tse_ptr->pkt_array[tse_ptr->chain_loop]->nb_buff is clear before passing // to SGDMA Driver uncached_packet_payload = (alt_u32 *)alt_remap_cached ((volatile void*) tse_ptr->pkt_array[tse_ptr->chain_loop]->nb_buff, 4); alt_avalon_sgdma_construct_stream_to_mem_desc( (alt_sgdma_descriptor *) &tse_ptr->desc[tse_ptr->chain_loop+ALTERA_TSE_FIRST_RX_SGDMA_DESC_OFST], // descriptor I want to work with (alt_sgdma_descriptor *) &tse_ptr->desc[tse_ptr->chain_loop+ALTERA_TSE_SECOND_RX_SGDMA_DESC_OFST], // pointer to "next" uncached_packet_payload, // tse_ptr->pkt_array[tse_ptr->chain_loop]->nb_buff, // starting write_address 0, // read until EOP 0); // don't write to constant address } I find the code in the TSE MAC IP. - Altera_Forum
I'm trying the same thing... have you come to a solution?
