15 years agoSGDMA debug
Hello, I am trying to learn how to use SGDMA to transfer data to memory. First of all, I am trying to connect SGDMA TX directly to SGDMA RX and check results. You can find the source code ->here<-...
12 years agoHi,
Is it possible to cycle multiple descriptors using the mSGDMA park feature? For example, in a MM-ST and/or ST-MM configuration, if the descriptor queue has two descriptors, and then "park" the queue so it becomes a circular queue? It would be a good feature for ping-pong buffers, for example... Cheers, Nestor
