15 years agoSGDMA debug
Hello, I am trying to learn how to use SGDMA to transfer data to memory. First of all, I am trying to connect SGDMA TX directly to SGDMA RX and check results. You can find the source code ->here<-...
14 years agoBadOmen,
Thank you very much. I will try it as your guide. Reference to the examples, I wrote my code. Care must pay attetion to the two diferrences: 1) descriptors are stored in on-chip memory, and just use a small piece of the memory in this test code. So how to solve the other ? 2) the buffers for ADC data is defined as an array, not allocate with Malloc() function. So I beg you to check my code again, please. Another question: how about the SGDMA data rate? In this test, the ADC is 200Msps.
