15 years agoSGDMA debug
Hello, I am trying to learn how to use SGDMA to transfer data to memory. First of all, I am trying to connect SGDMA TX directly to SGDMA RX and check results. You can find the source code ->here<-...
14 years agoIt can't transmit the ADC data and the busy bit of SGDMA status register is set as 1.
The first step is constructing a adc-to-ddr2-to-ethernet data path, regardless of the speed. But it's blocked again and again. Any advice,please.
