15 years agoSGDMA debug
Hello, I am trying to learn how to use SGDMA to transfer data to memory. First of all, I am trying to connect SGDMA TX directly to SGDMA RX and check results. You can find the source code ->here<-...
14 years agoNios II will struggle to move this data over Ethernet if you use TCP even if the input rate is 150MHz. Have you seen this?
http://www.alterawiki.com/wiki/nios_ii_udp_offload_example I've seen that design hit 1Gbps line rates.
