15 years agoSGDMA debug
Hello, I am trying to learn how to use SGDMA to transfer data to memory. First of all, I am trying to connect SGDMA TX directly to SGDMA RX and check results. You can find the source code ->here<-...
14 years agoSGDMA input is not connected? Also I see a bunch of adapters. I'd offer to create a component that wouldn't need such adapters at all.
How frequently ADC gives results? If it's 50MHz 8bit ADC, then You probably have no chances to do packet sending from Nios...
